Irc5550 rotation
  • copicatt
    • Nov 2008
    • 366
    Irc5550 rotation
  • Scottb
    • Apr 2013
    • 306
    Re: Irc5550 rotation
    just have them either place a blank sheet of paper on top of the check
    • techandtrader
      • Jun 2016
      • 335
      You could do that or program a LTR size in Mode Memory.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
      • copicatt
        • Nov 2008
        • 366
        • giogi
          Engineer senior
          • Jan 2016
          • 181
          Try to set up the device in this way:
          FUNCTION SETTINGS>COMMON>SCAN SETTINGS>AUTO SET DIFFERENT SIZE ORIGINAL WHEN USING FEEDER
          both settings to ON
          "Knowledge is a source, but unfortunately ignorance is a sea."
          • copicatt
            • Nov 2008
            • 366
            both settings to ON
            thanks. Will try that. So will that help with turning the wrong way off of the glass? Feeder does fine.
            • roho
              • Mar 2009
              • 844
              I think turning off auto rotation solves this, found somewhere in user settings.
              • beaker020
                • Mar 2006
                • 63
                (Settings/Registration) <Function Settings> <Copy><Auto Recognize Original Orientation>Off
                • Venom
                  Technical/IT Support
                  • Nov 2009
                  • 765
                  Scanning with OCR on automatically orientates your scans.
                  IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                  • BabbRust
                    • Jun 2021
                    • 1
                    Hi....the upkeep sign implies that the copier should be very much overhauled and checked if something is to be supplanted. Consumables like drum, sharp edge, fuser rollers, and designer are changed at such critical points in time. On the off chance that you are certain that you have supplanted the right part or nothing is to be supplanted, then, at that point you can continue to clear the sign.
                    • Venom
                      • Nov 2009
                      • 765
                      I got a headache reading this.
                      • giogi
                        Engineer senior
                        • Jan 2016
                        • 181
                        YES
                        but he didn't use google translator
