Canon Imagerunner Advance c5540i main controller
  • doug
    • Dec 2011
    • 198
    Hi guys,
    i have a Canon IRA C5540i that only the sleep mode button is blinking...am i right with thinking it is the main controoler?
    If so, how do I replace this?
    Any input would be gratly appeciated and how is this done?
    Doug
    Re: Canon Imagerunner Advance c5540i main controller
    Originally posted by doug
    Hi guys,
    Doug
    i would try firmware or HDD first.
    • Hishamawada
      • 174
      mainly it is main controller issue , but as mentioned above you can try installing a firmware first . Hdd i dont think it have anything related to the issue.
      Sent from my SM-G610F using Tapatalk
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5012
        Pull out main controller.(30 sec).
        4 pcb from old mc install on new main pcb.
        Install firmware.
        First try just reseat main controller.One screw and pull out and back in.Turn on with holding 2 and 4.
        • giogi
          Engineer senior
          • Jan 2016
          • 181
          on the service manual there is a special chapter: Startup System Failure Diagnosis
          flow chart with indications how solve your problem
          "Knowledge is a source, but unfortunately ignorance is a sea."
          • fchu5959
            Field Engineer
            • Jun 2010
            • 100
            +1
            The c 55xx series is totally different from the c52xx series as far as the electronic architecture is concerned.So ,it is of utmost importance to read and study the service manual before start troubleshooting this machine.This will help you to save a lot of time and headache when you have a start-up issue.
            Check the status of the LEDS on the control panel as well as those on the different PCB's(Riser,main Controler, etc) and follow the flow chart to troubleshoot any start-up issue.
            Usually this turns around :
            Power supply assembly
            Riser pcb
            Cables(micro usb/mini hdmi)
            control panel
            Main controler board.
            Good luck.
