Canon ir 3300 Printing Problem
  • maddy4u
    • Feb 2010
    • 19
    [Misc] Canon ir 3300 Printing Problem
    Hi everyone
    i need help in Canon ir 3300 printing Problem. Please Look the attachment & Help in this regards.
    Action Taken:- Transfer Roller Change
    HVT Unit Change
    Leaser Unit Change
    Drum/D.P. Unit Change
    Still this problem in not Solving
  • Brian8506
    • 1664
    Re: Canon ir 3300 Printing Problem
    Assuming the drum is good and there's not alot of moisture in the paper, I would vacuum out the dv unit, dry wipe the cylinder and put in fresh toner.
    • maddy4u
      • Feb 2010
      • 19
      Hi
      Thanks for your reply. i changed whole Drum Unit & Developer Unit from another machine which is working fine. & Drum and Developer unit is also working fine in another machine
      Regards
      • Brian8506
        • 1664
        • maddy4u
          • Feb 2010
          • 19
          Hi
          I Have Tried everything Fresh Paper, Two Sided still no success at all. the problem arise after replacement of fixing motor unit
          Regards
          • Brian8506
            • 1664
            • techandtrader
              • Jun 2016
              • 330
              Does anyone need a like new feed assembly for this model?
              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                Stop the print half way and see if image is good on drum, if good...you have a transfer problem, if bad...you have a developing problem
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                • Brian8506
                  • 1664
                  I typed varistor and got barrister
                  • maddy4u
                    • Feb 2010
                    • 19
                    Thanks all for your valuable Suggestion. Some Biasing make this problem
                    Regards
                    • Brian8506
                      • 1664
                      Regards
                      What did you have to do to fix it?
                      • techandtrader
                        • Jun 2016
                        • 330
                        Sounds like he adjusted bias on the developer.
                        • Brian8506
                          • 1664
                          It would be nice if people would come back with a solution because it may help someone else in the future and help us know whether or not we helped
                          • maddy4u
                            • Feb 2010
                            • 19
                            Hi
                            Problem is solved by Changing the U Type Copper Parts Behind Developer Unit . i think it will charge the developer unit
                            Regards
