IRA- C5250 Black dots all colors
  • copycart
    • May 2009
    • 97
    I have one these copiers that is putting black dots or spots on the copies. Each individual color has the save problem, they are there whether internal print or copy. The spots do move, which lets me know that they are on a moving part. I get the same pattern on black as on single color copies. Fuser looks great, can't be the drums because as stated, it same pattern is there regardless of which drum is used. I pulled the ITB unit and didn't see any problem. Going to take a look at the ITB drive roller. Any ideas on this one will certainly be appreciated.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: IRA- C5250 Black dots all colors
    You may have to scrub toner blob off black mag roller
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Hishamawada
      • 174
      A picture will help a lot , but as you have explained it could and issue with the black assembly , swap the black drum with any other color and if the color of the dot changes then its a drum issue.
      • copycart
        • May 2009
        • 97
        I ran a single magenta, cyan and yellow copy and get the same dot image. I would think in these cases the only drum or DV unit being used is that particular color. I swapped the fuser to no avail and can see no problem with the transfer belt unit, no visible signs of dots or areas not being cleaned. poor image is only on the rear side of copies 11 X 8 1/2. I will try and scan some copies of what it looks like. Shows up on test pattern 10 and 6
        • copycart
          • May 2009
          • 97
          file:///var/mobile/Library/SMS/Attachments/65/05/8DC34C5A-430D-4818-B041-B70DB98F3EE4/64668065495__7BB6E54E-07A1-4D23-9AFC-9BE1DA8FCA9E.HEIC
          not sure if this picture will come up
          • Hishamawada
            • 174
            Even if you print only 1 color , all the drum turn , get charged , discharged and if there is any damaged spot it will pick up toner and appear on the prints. Just check the black drum and update me with the results
            Sent from my SM-G610F using Tapatalk
            • hidius
              • Jun 2015
              • 128
              black drum unit will be your issue. probably the cleaning foam roller disintergrating on the drum unit. take it out and have a look
              • techandtrader
                • Jun 2016
                • 335
                I had this going on with the three colors. It was back side about 1/2 inch thick of small toner specs. I cleaned the drums really good and finally transferred them to a different machine. Either I was finally able to clean it or the recalibration stopped it in that machine. Use your Loupe to make sure.
                Found the problem again and it was the PCR were crap and caused damage to the charge roller. I was not able to clean the charge roller to a point where they would stop the intermittent specs so the roller was changed. Problem solved and good thing because the drum was in like new condition.
                I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Have you samples what's the drum lifes
                  Regards Mark
                  • copycart
                    • May 2009
                    • 97
                    Thanks Guys, The black Drum unit was the problem
