Canon IR Adv 8105 E808-03/08
  • tinnyjay
    • Oct 2009
    • 663
    Hi,
    I am facing a problem with ir adv 8105. I have changed thermistors and rollers, but e808-03 and e808-08 come time after time.
    Error 808-03 is FM7 because of clogging but 808-08 cant find it.
    Any help is really appreciated.
    "Who loves the roses,must also bear thumbs"
  • Brian8506
    • 1665
    Re: Canon IR Adv 8105 E808-03/08
    I had the same code on a 6255 and it ended up being the AC driver
    • Hishamawada
      • 174
      i would suggest you to dismantle the heater and install it again . check the connections , wires , bent pins , clean from dust .
      if the error persist , tell me i will guide you further
      Sent from my SM-G610F using Tapatalk
      • tinnyjay
        • Oct 2009
        • 663
        Hi,
        I changed AC Driver PCB Assy (FM4-1088) and IH POWER SUPPLY PCB ASS'Y (FM4-1092) and still the same.
        • tinnyjay
          • Oct 2009
          • 663
          I did what you said but e808-08 comes time after time again.
          • tinnyjay
            • Oct 2009
            • 663
            The temperature of FIX UE and FIX UE2 is higher than FIX U by 5-6 degrees during printing.
            After 1 minute in this state the error comes up.
            Can it be heater or side thermistors?
            In any rare case it shows up E01-03
            • Hishamawada
              • 174
              If your getting E001 error , and the heater is heating up then you need to check this connector at the rear.
              I need to know the upper fixing condition, and the thermistors (main and the 2 sub) ? you can replace the thermistors .
              you can also check the fuses of the fixing powee supply pcb (Pcb10) . i dont think so but better check it specially FU19.
              If all of this didnt help, you can try the main driver pcb (pcb2)
              And a last option i would think of a Dc Controller issue ( you can try clearing Dc Con Also).
              best of luck
              • tinnyjay
                • Oct 2009
                • 663
                best of luck
                I changed PCB10
                • tinnyjay
                  • Oct 2009
                  • 663
                  best of luck
                  _________________________________
                  Case closed.
                  The cooling plastic above the fuser unit (also under Fuser IH), was broken and the heat caused E808-8.
                  Thank you so much all of you.
                  Regards,
                  • Hishamawada
                    • 174
                    Thank you for updating on the issue and how it was solved
                    This should be the case for every case.
                    If you have some photos for the broken plastic would be good .
                    • tinnyjay
                      • Oct 2009
                      • 663
                      The plastic over fusing unit.
