Canon Ir adv c7270i paper sauce problem.
  • Age102
    • Sep 2014
    • 8
    Canon ir adv c 7270i when photocoping and printing both off the glass and using DF .Error message appears after one copy. The paper feed type size is different from the paper type size registered to the paper source load correct paper. When you resume printing allows only one copy at a time. Default paper size is A4. Checked auto paper select all good . Manually select A4 same message appears.
