Canon ImageRunner Advance C9280 Pro | "Fixing Feed Drawer Connection Error"
  • drect
    • Feb 2021
    • 5
    [Error Code] Canon ImageRunner Advance C9280 Pro | "Fixing Feed Drawer Connection Error"
    First time poster. Hi everyone, thank you for considering helping me. For weeks and months I've been facing this issue I cannot find a way to resolve.
    I turn on the device and see the error : "Insert the transfer fixing unit as far as it will go."
    Usually, I open the fixing assembly door and close it immediately, once or twice, and this will clear that error.
    Then, I am faced with another error, E000006-0002. I looked this up on the manual which reads:
    Fixing Feed drawer connection error
    Description of detection: Fixing feed knob of fixing drawer is abnormal (Sensor cannot detect)
    Measures: 1. Fixing feed knob of dixing drawer has connection failure, 2. Wire harness failure, 3. Sensor failure
    I have no idea what to do at this point. I accidentally lookup up this error incorrectly on the manual and replaced the fixing film unit.
    When shutting off the unit, it makes a strange clicking noise for five seconds before shutdown is completed.
    Any ideas or guidance, please, anyone?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    Re: Canon ImageRunner Advance C9280 Pro | "Fixing Feed Drawer Connection Error"
    https://www.copytechnet.com/forums/a...5-pro-tp12-pdf
    • drect
      • Feb 2021
      • 5
      thanks zoraldinho, that's a super useful guide for me.
      helps me condider narrowing it down to replacing the fixing drawer assembly or the fixing drawer cable.
      i wonder if the first error being the non-detection of the drawer correctly closed suggests one or the other. that error goes away by spoofing it with opening and closing the door.
      • zoraldinho
        • Mar 2008
        • 5006
        Usually is just a piece of paper in the connector.
        • drect
          • Feb 2021
          • 5
          fixing-drawer-scaled-1200x628.jpgfixing-drawer-2-scaled-1200x628.jpg I don't know the name of it yet but this connector I will like to inspect! I read somewhere pins can be distorted from it for example. It's an awkward reach in there so unsure how to start on it.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Originally posted by drect
            [ATTACH=CONFIG]49649[/ATTACH][ATTACH=CONFIG]49651[/ATTACH] I don't know the name of it yet but this connector I will like to inspect! I read somewhere pins can be distorted from it for example. It's an awkward reach in there so unsure how to start on it.
            Being a end user you may be best to call a credited service engineer.
            You can pull the draw out more look on the rail push the two leaf springs in may help to see more
            Regards Mark
              +1 to the suggested
              • drect
                • Feb 2021
                • 5
                Hi, thanks to all posters and viewers for the valuable input!
                Can someone indicate how I can find a correct service engineer to look at it? I am in Miami.
                However, as end user I also quite enjoy learning the technicals of this machine, for example I put it together, and also I just replaced the film fuser.
                On the diagnosis side, given that there is the fixing feeder error first and once that is handled, there is the E000006-0002 error, which reads as some sort of sensor error, I thought maybe I should try to replace the Fixing Drawer Assembly.
                Any feedback on engineer, or this route of troubleshooting I am considering? Or other ideas!
                Best wishes to all
                PXL_20210712_205037185-scaled-1200x628.jpgPXL_20210712_205025949-scaled-1200x628.jpgPXL_20210712_205228949-scaled-1200x628.jpgPXL_20210712_204746851-scaled-1200x628.jpgPXL_20210712_204859680-scaled-1200x628.jpgScreenshot_20210711-221600-scaled-1200x628.jpg
                • drect
                  • Feb 2021
                  • 5
                  Hi bump, I am gonna try replacing the fuser plug (FM0-2095-000 Fixing Drawer Assembly). Any tech's opinion as to whether this is a good idea or bad idea?
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Best wishes to all
                    [ATTACH=CONFIG]49676[/ATTACH][ATTACH=CONFIG]49677[/ATTACH][ATTACH=CONFIG]49678[/ATTACH][ATTACH=CONFIG]49679[/ATTACH][ATTACH=CONFIG]49680[/ATTACH][ATTACH=CONFIG]49681[/ATTACH]
                    I think you should call Canon have you also noticed the control panel isn't showing the finisher it could be related good luck
                    Regards Mark
