Installation of ImagePass B1 on Canon C5030i
  • acomp
    • Jul 2021
    • 3
    Hi,
    I'm trying to install an ImagePass B1 controller on a canon C5030i. So I installed the interface board in the copier, connected the EFI controller to the copier and changed the IMG-CONT to "3". As I start up the copier, the display on the rear of the ImagePass shows "00". Now my question: How can I access the ImagePass? Is there a special menu for it? How can I assign an IP Address to the ImagePass? The standard IP v4 settings have disappeared in the canon setup options since I set up the ImagePass.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Installation of ImagePass B1 on Canon C5030i
    • acomp
      • Jul 2021
      • 3
      Thanks a lot! That was the thing I was looking for. Works perfect now.
      • acomp
        • Jul 2021
        • 3
        Thank you for the advice. I already had installed the crossover cable but didn't know how to configure the RIP.
        • zoraldinho
          • Mar 2008
          • 5007
          No problem.
