No Toner in devloping assembly canon ir advance 8205
  • Omkarmore
    • 17
    Hi,
    I have Canon Ir Adv 8205 but i need to supply toner to devloping assembly manually using service mode.
    I checked Buffer unit is working fine
    Devloping assembly toner sensor is working
    What can i do ?
  • Hishamawada
    • 174
    Re: No Toner in devloping assembly canon ir advance 8205
    Hello , the stirring rod inside the developing unit is broken, causing the machine to think that the developer unit is full .
    You need to change it. you need to check it at the gears , location.
    If you need anything else tell me.
    Sent from my SM-G610F using Tapatalk
    • Omkarmore
      • 17
      Is one of the stirring rod is connected to spring
      Plz tell me
      • Brian8506
        • 1665
        • Omkarmore
          • 17
          Yesterday I opened developing assembly
          3 rod are broken and one spring is there
          How to connect that spring
          Plz tell me about that spring
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            You will need to replace the broken rods
            Regards Mark
