Squeaky C1127
  • Londo
    • May 2021
    • 16
    Squeaky C1127
    Problem with squeaky C1127, find out it was from ITB, can't find anything wrong with it but after new ITB fitted all ok. Now after few months same problem , anyone has similar problem and find what make squeaky noise in ITB?
  • Radiscar
    • Jun 2019
    • 74
    So take this with a heaping grain of salt, another tech told me that you use compatible toner... personally I wonder if it's due to the amount/type of toner being used? If you have one to play with maybe sprinkle some toner powder, lubricate powder, baby powder (whatever you usually use) onto the belt to lubricate and see if the noise goes away?
    If it does work, probably the cleaning blade is squeaking/rubbing on the belt?
