How to configure the device to send copy and print counters daily ?
Billing counter
Tags: None
As I understand I need to use the email sending settings on the copier, what exactly do I need to configure?Comment
The configuration is done on the device, but the device also needs to be equipped with the appropriate FW,
the meters are received on a simple application in the cloud. I will send you the instructions via private mail.Comment
I would like to ask how I could use such a function. Currently,
we use the generally known PF. but installation is cumbersome and often impossible or stops working. We now have more problems obtaining data for billing services.Comment
