Help ...How to delete IR3320 hard disk data
  • ys6911
    • Aug 2025
    My company want to sell this ir3320 copier, they want to permenant delete hard disk data from this copier, how to perform it?
  • Irish
    • 110
    Im Guessing Format HDD in service support tool ???
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Irish has the answer, just format the drive, then reload system software using the ALLHDF choice from the service support tool menu for the 3320. You then have a virgin machine. with no passwords, mailboxes, fax data etc...
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        You can also take the drive out..hook it up to a PC and format the drive that way.
        Also..just for people's further info...Canon sell a permanent file deletion software for their copiers.
        If you DO remove the drive to format in a pc..remember that their are 5 partitions on the disc and not all of them will show up in FDISK...make sure that the size reported matches the size of the HDD.
