Canon IRC C750 error 061-0001 and error 193-0110
  • bryant28282000
    • Jul 2012
    • 147
    Does anyone know what these two codes mean? The service manual list like a thousand things for these codes.
  • Hishamawada
    • 174
    Re: Canon IRC C750 error 061-0001 and error 193-0110
    For error e061-001 :
    First try removing the primary corona and installing it back .
    Try removing patch sensor PCB connectors and connecting them back .
    it could be high humidity issue.
    Check Relay PCB connections.
    Next try replacing primary Corona
    • bryant28282000
      • Jul 2012
      • 147
      Can I lower the humidity in Diagnostics?
      • Hishamawada
        • 174
        No you need to lower the humidity in your site .
        early at the morning when you turn ON the printer go to service mode -> display-> analog if the humitidy is around 60% and more I suggest to put a humidifier and keep it working all the time .
        the humidity beteeen 40-50 is good.
        Sent from my SM-G610F using Tapatalk
