strange problems
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    strange problems
    hi technician ....l have strange problems ....well l have canon 6521 and it have an film transporting in here fixing systeme ..so l shanging this film after there ...if l started this copier he affiched E000 and after there the copier off on ....please can you healpe me
    BEST TECHNICIAN . NICE PEOPLE .
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    My guess would be that you've left the heating lamp unplugged..as it's a thermistor read error...if it was the film unit it'd be an E007.
    • davidj7
      • 1107
      oze i have seen E000 in 6060's . I am dont remeber what the error stands for, long time ago, replaced my bootrom when the iR series came. zaza could you tell us why you opened the fixing in the first place other than replace film
      a machine is only as good as your tech : source:screwtape ; the scary one
      • zaza
        MECANOGRAPHE
        • Mar 2008
        • 1095
        ok
        ok dear friends but ...this film ho l change is very good in other copier ...if l placed in other copier 6521 ....so l don't know whey this copier has off after this code affiched there ....but the systeme fixing not have the heat lamp ..please can you more explain ...
        • costd
          • Jan 2008
          • 409
          A real swag but try resetting the error in service mode then power cycle. Seems to me when we get a eooo on most units we try a reset first - then it will either work or give an e001. Do not know why they say power off/on as I personally do not know a time when that works. Always takes clearing the error, then a power cycle (off/on).
          Your milage may vary.
          • zaza
            MECANOGRAPHE
            • Mar 2008
            • 1095
            tell me friend
            hi dear friend COSTD please can you tell me how can l started service mode of this copiers ???
            • mrfixit51
              Lead Service Technician
              • Oct 2008
              • 1975
              Hello zaza,
              I have created 3 documents that may help you. The Service Mode one tells how to get into the mode and how to reset E000. I never had to work on the fuser of this model, and I am eternally grateful for that
              I believe the previous post on this is dead on correct. You may be lucky and the reset may get you back on the road.
              Good luck,,,
              • zaza
                MECANOGRAPHE
                • Mar 2008
                • 1095
                realy ...
                Originally posted by mrfixit51
                Hello zaza,
                Good luck,,,
                thank you very much for your suggission dear friend mrfixit51....but l thing l replaced this fixing film ....
                • davidj7
                  • 1107
                  i am lost..........
                  • Brian8506
                    • 1665
                    Cheat front door, turn on and quickly hit service switch in small hole in upper left by exposure dial then pull door cheater. This resets fuser codes but you have to be fast before machine turns off.
                    • zaza
                      MECANOGRAPHE
                      • Mar 2008
                      • 1095
                      never ....
                      ok friend Brian l will do it this operation in the past ..but it's never ... l try to started the service mode and reset this code error ...E000....
