4225i Stuck on boot
  • rockboy69
    • Aug 2018
    • 9
    [Misc] 4225i Stuck on boot
    'm hoping you might be able to help me with an issue i'm having with 4235i.
    it was not connecting to emaintenence and when i checked all the settings were correct but still not communicating so i decided to reset the emaintenece connection settings by running [Copier>Option>Clear and now my screen is stuck in a loading (sperm line) and will not boot to the home screen.
    How do i get inot service mode at boot up?
    2
    OKi
    0%
    0
    CANON
    0%
    2
    The poll is expired.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: 4225i Stuck on boot
    You can't get into service mode from boot. What did you clear?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • roho
      • Mar 2009
      • 844
      I have only been able to hit service mode without fully booting up on a couple occasions. The task bar has to be about 2/3,3/4 across the screen or the device won't hit service mode as it hasn't completed enough to do so.
      I wouldn't clear anything for that kind of situation, would have looked at running a com test.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Try hdd recovery or firmware
        Regards Mark
        • rockboy69
          • Aug 2018
          • 9
          thanks guys i managed to fix it by re-installing the firmware technically i just updated it. and reinstalled ULM.
