my problem with this copier is that display says error 001 what should I do?I checked fix unit and It is okay. the paper is jammed in the fix unit. thanks.Maybe I have to reset it?
canon ir 2016 001 error
E001 İS
0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
you have to reset code from service mode.
first push *(technician pad) then push 2-8 same time then again *(technician pad)
you will enter service mode find clear push okey pad then find error menu and you know later ok?(sorry for my english)
add me when u need help with canon
froozen2005@gmail.com
Bundan ötesi ;
Ya İSTİKLAL , Ya ÖLÜM!Comment
E001 Reset
, and the software is much harder to work around than the service mode on a "real" copier.
canon ir 2016 error 001
thanks everybody,I want to know If I can install the fixing film unit (FM2-0359-000) to this copier.It is for 220vol.Comment
are you a business machine mechanic?..... it doesnt matter if its 220 or 110 they're just the same procedure when replacing fixing film...
replacing fixing film is quite easy but its complicated if your not copier tech'n and fixing film can rip apart if you dont know how to do it but if you have the guts to do it. one tip, on one side of the fixing film thare is a white rectangular shape mark that is for the sensor (you'll see this sensor at the bottom of the fixing unit covered with a hard plastic.) if you reversed it and run the machine it'll give you e007...Last edited by Zoren; 03-06-2009, 07:38 AM.Just came out from hybernation.....Comment
Thanks friends,I could solv the problem ,But I didn't need to reset the copier,The fixing unit was bad.Comment
