Sorter Problem....with IR6000
  • wilson
    • 27
    1) The printing for my machine will be o.k if i put only one piece of paper on the feeder. The printing will come out exactly as i want but ....
    a ) if i put two pieces or more on the feeder, the paper will not come out from the sorter.. I tried to check with the roller in the sorter and the roller does not move in order to allow the papar to pass throught it.
    b ) I do not know what is the problem because if i put one piece of paper on the feeder... The roller in the sorter will move again.
    c ) What can i do in order to let the paper pass the sorter because the gear and the belt for the roller is still good in functioning....Or is there anything wrong with my sorter ??
  • Zoren
    Technicien de copieur
    • 99
    during multi copies jams right....
    on the fixing side there is a guide that moves the paper to reverse during multi copies, check your paper reversal guide on the rear side there is a small white plastic that holds a small spring that makes the reversal guide to flip... check it out the plastic is broken that holds the spring...
    Just came out from hybernation.....
    • wilson
      • 27
      multi copies
      Checked already the small white plactic which hold the spring but still cannot do multi copies.....
      The machine can do multi copies if i put papers on the bypass but it cannot sort out your paper according to the sets you want....
      • Zoren
        • 99
        i think you did not even removed it.... checked again that plastic thoroughly you wont noticed it but it cracks... you will not see the cracked by just looking at it
        • wilson
          • 27
          6045 reversing flip,...
          Yes... it cracked... and now i am removing it ... I do not have the spare part here .. so i just fix it with the Canon 6045 PART...Not doing well and still remain the same problem...
          Anyway. Do you think the problem come from the solenoid ??
          • Zoren
            • 99
            you already said that the plastic spring holder is cracked... dont put your mind on the solenoid its not the problem.......
            "remedy" the plastic holder or replaced it with a new one... if i am in front of your machine that problem is easy and i'll be charging you $200 for a 5 minutes work......
            use your imagination how you can remedy that broken plastic spring holder....
