Source for IR 3300 series hard drives
  • copymon
    • 39
    Looking for a place to buy IR 3300 compatible hard drives, Fujitsu, seagate, as long as it can be added to the IFT. Thanks
  • Kopyrtek
    Copier Psychologist
    • Jan 2007
    • 407
    You can look online or call Nationwide.I prefer the Hitachi drives as i think they last somewhat longer than most and you can add them to the .ift file.
    • copymon
      • 39
      Thanks, what is the drive number on the ones your using?
      • Kopyrtek
        Copier Psychologist
        • Jan 2007
        • 407
        I use the Hitachi 20g HTS541020G9AT00 and the Hitachi 40g HDS728040PLAT20.
        • copymon
          • 39
          Thanks!
          • Kopyrtek
            Copier Psychologist
            • Jan 2007
            • 407
            Give a BIG shout out to Phantom Tech.I got the information from his post on another question.
            • kuby
              • Oct 2007
              • 1396
              Supported hard drives for Canon ir3300
              Fujitsu MPC3032AT
              Fujitsu MPD3043AT
              Fujitsu MPE3064AT
              Quantum FireBall CX6.4A
              Quantum FireBallLct10 05
              Quantum FireballLct08 04
              Quantum FireBallLct15 07
              Fujitsu MPF3102AT
              Toshiba MK6014MAP
              Toshiba MK6015MAP
              IBM-DJSA-205
              IBM-DARA-206000
              Fujitsu MHK2060AT
              ST34311A
              ST34313A
              ST310211A
              Fujitsu MPG3102AT E
              Quantum FireBallLct20 10
              Toshiba MK1016GAP
              IBM-DJSA-210
              Fujitsu MHN2300AT
              Toshiba MK6017MAP
              Maxtor 2B020H1
              Maxtor 4K020H1
              WDC WD300AB-00BVA0
              Samsung SV2001H
              Maxtor 2F030J0
              ExcelStor Technology J120
              Samsung SV0211H
              ST340015A
              Toshiba MK2023GAS
              Samsung SV0221N
              Toshiba MK2023GAS
              ST92011A
