error E-0061-0001 C800
  • Ronaldo Virgili Floriano
    • Feb 2023
    • 17
    Good morning, gentlemen, I have an ImagePRESS C800 equipment showing an error code E-0061-0001.
    I have already replaced the cylinder, primary corona, pre-transfer, PCB patch register and the problem persists. Has anyone had this problem and found a solution? I am moving on to HVTs and transformers.
    Thank you in advance.
  • Brian8506
    • 1667
    I donโ€™t know that machine but thatโ€™s a hard drive code
    • nicknt82
      • Nov 2011
      • 155
      Hello, i solve this error before add my whatapp, i will support you by video call
        • Feb 2023
        • 17
        Hello, problem solved, PCB HVT Black burned, thank you
