Canon v Kyocera
  • dickierock
    • 252
    Canon v Kyocera
    Hi,,does anyone here who has serviced both Canon and Kyocera have an opinion how servicing, reliability,,
    installation,, software,,etc compare.
    Which do you prefer and other info you would like to share
    would be most appreciated.
    Re: Canon v Kyocera
    Wow....
    What are the needs of the customet?
    What is their budget?
    Any special options needed.
    You need to clarify.
    • bret@cos.flag.org
      • Jun 2020
      • 99
      Re: Canon v Kyocera
      I've been a network admin for both and an advanced user of both, but I've only serviced Canon machines.
      I would say from what I know, in general, notwithstanding user needs, etc. that Canon machines are superior in quality, reliability and longevity.
      That could be influenced by the fact that I've dealt with more higher-end Canon machines and lower-end Kyocera machines, and like I said, I've not serviced Kyocera machines, so I may be a bit bias. But there's my opinion, clearly stated as such and under what parameters.
      Hopefully that helps you a bit and doesn't evoke angry rebuttals from others that know more than me.
      • dickierock
        • 252
        Re: Canon v Kyocera
        Wow....
        I'm not talking in terms of sales.
        I'm enquiring as to the service side as I may be moving onto fixing Canon machines.
        • ReproKev
          • 273
          Re: Canon v Kyocera
          Canon hands down.
          Of course I'm heavily biased because 90% of the machines I work on and 100% of the machines I sell/rent are Canon's. I have worked on a few Kyocera's and haven't really liked them. They don't seem as well made to me. Maybe it's a Ford vs Chevy thing, or a familiarity thing, but that's my biased opinion fwiw.This IS the Canon forum though, so....
          • craigster
            • Apr 2016
            • 201
            Re: Canon v Kyocera
            I service both models and like the Kyocera better for the 3 year warranty program and the simple replacement of fusers and transfer belts which you have to rebuild in canon. Canon does have a better image for color though. There are times I change the emulation on the machine to help with the kyocera image. I think the cost savings with Kyocera is worth it.
            Just my opinion!!
            • techandtrader
              • Jun 2016
              • 335
              Re: Canon v Kyocera
              Canon is the Cadillac and Key is the grand am. Some of the Color keys can be extreamly expensive when the drums go out .... needing dev and other parts. That machine was a higher end model in a print shop. I was shocked at how much the engine cost to rebuild. Customer called dealer to come get it. Nothing but trouble.... No wonder they refuse to keep agreements on those for too long.
              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
              • ElZero
                • Sep 2021
                • 24
                Re: Canon v Kyocera
                Well, I serviced Kyocera products around 9 ago, switched to Canon 2 or 3 years later. I had a lot of problems and malfunctions with kyocera, especially the smaller ones. Canon products are running more stable, are lasting longer. but i can not compare with todays kyocera hardware. i would prefer canon, if i had to choose.
                • tech28
                  • Jun 2013
                  • 434
                  Re: Canon v Kyocera
                  Canon , hands down! To replace fusers, transfer belts, drums, developers, most everything, the engineering is far superior on the Canons. Serviceability is great. Quality, non better.
                  from my experience. Have seen them, Kyo's ,K/M's, Sharps, Tosh, have sold em at one time or another, and serviced them. Canon! Been playing around with machines for over 36 years.
                  • Big Flo
                    • Jun 2018
                    • 15
                    Re: Canon v Kyocera
                    I service both--with official technical support for both. Canon is by far superior in build quality and user experience that comes with it.
                    • dickierock
                      • 252
                      Re: Canon v Kyocera
                      Looks like Canon is the preference for the majority.
                      Thanks all for the input. 👍
                      • copiertec
                        • Jan 2016
                        • 2211
                        Re: Canon v Kyocera
                        An interesting post with some good responses.
                          • 16407
                          Re: Canon v Kyocera
                          I don't know how much easier it could possibly be to replace the supplies than on Kyocera. I removed all the drums and DV's on a 2552ci and didn't even need a tool.
                          • tonerhead
                            • Sep 2009
                            • 582
                            Re: Canon v Kyocera
                            Have serviced both for dealerships. Canon much more reliable IMO. Kyo definitely has better warranties though. So for smaller accts with low copy volumes, maybe Kyo might save some money. Not a big fan of Kyo although the older KM series b/w were bulletproof IMO. I do think Kyo is a little better on the connectivity side of things though. Worst for connectivity is Ricoh IMO.
                            I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
                            Especially when it comes to sex
                            • D_L_P
                              Self Employed
                              • Oct 2009
                              • 1196
                              Re: Canon v Kyocera
                              I worked on Canon's for 15 years. The last being the first ir advanced series. The last Kyocera's I worked on was the taskalfa 6501, 3050, and 7550ci.
                              Canon is better.
                              The Kyocera is modular, meaning things come apart easy (except the interlocking covers). But ... Kyocera's run dirtier, have more components fail, and their warranty stuff is nice but complicated.
                              I miss Canon service calls where you replace some consumables, an easy cleaning and you're off to the next call. You hardly ever need to mess with clutches, sensors, one ways, etc with a Canon.
                              Kyocera on the other hand seem to have flaky sensors, weak clutches, and feed rollers that haven't improved since the 1990's.
                              When Canon came out with that soft sponge roller I saw paper drawers regularly going 200k before having any jam issues.
