Canon 400if
  • glenbennett
    • May 2015
    • 68
    Canon 400if
    I have a canon 400if actually two and I can't seem to find it on my network. I have done all the proper IP settings. I even went into service mode and hit clear then MMI and it wiped out everything and I started all over again. Am I missing something? Both machines. Is there a way to test the network card even DHCP doesn't seem to work although it does hold the static IP. Please help me connect to my laptop. I have a delivery in the morning.
    Thank you,
    Glen Bennett
    Thank You,
    Glen Bennett
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon 400if
    Go to service mode copier / function / system / fix-ip
    The printer obtains ip 172.16.1.100
    On the laptop, change ip to 172.16.1.101
    You are connected to a printer.
    First upgrade firmware.
    • glenbennett
      • May 2015
      • 68
      Re: Canon 400if
      I am in service mode this morning there is no "fix-ip" after I hit system. Also where can I get firmware? Can you please email it to me?
      glenbennett66@gmail.com
      Thank you
      Thank You,
      Glen Bennett
      • zoraldinho
        • Mar 2008
        • 5007
        Re: Canon 400if
        Fix ip:
        Other option:
        Turn off printer.
        Turn on while holding 1 and 7
        Upgrade firmware:
        If the printer network has Internet access go to the menu:
        data management / license-other / upgrade firmware
        select the latest version and download
        Once the firmware is downloaded click to install.
        • glenbennett
          • May 2015
          • 68
          Re: Canon 400if
          Fix ip:
          Other option:
          Turn off printer.
          Upgrade firmware:
          Thank you
          I went into data management / license-other there is no upgrade firmware in there. I reset the whole machine to default now my switch box does not have a green light going to my network card. Am I missing something?
          Thank You,
          Glen Bennett
          • glenbennett
            • May 2015
            • 68
            Re: Canon 400if
            Originally posted by glenbennett
            Thank you
            What firmware should I download?
            Thank You,
            Glen Bennett
            • zoraldinho
              • Mar 2008
              • 5007
              Re: Canon 400if
              Also in service mode you have "updater" on the first page
              The latest of course. They are marked by dates and versions.
