imagepress c700
  • chughtai
    • Sep 2021
    • 25
    [Misc] imagepress c700
    hi everyone good afternoon
    i am facing front side light copy i change complete image formation drum unit/dev unit/charge assemble/pri transfer assembly and transfer belt unit
    but problem still same if some one encounter this problem plz give me advise.
    see attacment
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: imagepress c700
    Clean patch sensors and drum encoders.
    • Hishamawada
      • 174
      Re: imagepress c700
      Hello, encoder doest cause such problems.
      First is the problem only on black ?
      If yes , then print Grid-Adj , if issue is not visible then its a laser issue.
      If it is visible , check the primary transfer roller under the itb , check its bushings and try replacing it .
      Sent from my MAR-LX1A using Tapatalk
