Canon imagepress c6010 Dens problem
  • burak
    • Feb 2019
    • 38
    Hello there,
    I have Canon c6010 abnormal dens problem.
    In ground works, the dens value decreases to -5%, the machine gives error e020-0481-05. In normal jobs, the dens value is around -2.50%.
    I changed the developer and the drum today, the problem does not go away. I cleaned the atr sensor many times, the result did not change. I cleaned the laser and the result did not change. I use oem toner.
    Re: Canon imagepress c6010 Dens problem
    Originally posted by burak
    Hello there,
    please help [ATTACH=CONFIG]50349[/ATTACH]
    Did you run the adjustments after install?
    • Hishamawada
      • 174
      Hello,
      Did u clean the patch sensor ?
      Did u put new starter black ?
      Did u perform all the needed adjustment?
      Update me to proceed with what u need to do next
      Sent from my MAR-LX1A using Tapatalk
      • burak
        • Feb 2019
        • 38
        Hello again,
        Starter is new. I have made all the necessary adjustments.
        but the machine seems to be unable to transfer the required amount of toner to the developer unit.
        waiting for your valuable ideas
        • Hishamawada
          • 174
          Did you clean te patch sensor?
          Sent from my LDN-L21 using Tapatalk
          • burak
            • Feb 2019
            • 38
            of course cleaned the patch sensor many times.
            • Hishamawada
              • 174
              Perform PT-LPADJ and test
              • burak
                • Feb 2019
                • 38
                I performed the PT-LPADJ process.
                but after 100 prints the error came back.
                dens value decreased to 6% for black.
                I couldn't find a solution
                • Hishamawada
                  • 174
                  Do u have another developing unit to test on it?
                  If not try swapping the sensor with another unit.
                  And Check is the developing pressure good? When u push the unit to the drum , check if there is anything not right.
                  Send me a 50% black Pg and 100% black Pg.
                  Try swapping coronas
                  • fchu5959
                    Field Engineer
                    • Jun 2010
                    • 100
                    After cleaning the black patch sensor and performing the PT-LPADJ,check the values of Dens/window K.it shoud be around 1000 and also the value of P-DA-k and compare it to the values of the 3 other colors.if it is clean,it should give a low value;otherwise it means that the sensor is still dirty and should be replaced.
                    There is a thin plastic film on the sensor;so this sensor should never be cleaned with alcohol or any other solvent;you can use a blower to clean it.
                    Hope this info would be of some help to resolve this issue.
                    • burak
                      • Feb 2019
                      • 38
                      Hello again
                      I did the PT-LPADJ process. window value 1000
                      I removed the patch sensor and cleaned it.
                      I cleaned all the toner pipes + subhopper to see if it was clogged.
                      but the result did not change. the toner flow is fine up to the subhopper, but there is a problem between the developer tank and the toner calculation.
                      When I rotate the subhopper with my hand, the dens value is recovered. but the machine itself does not supply enough toner to the deveopler tank, the dens value drops to -6%, the machine gives e20 code.
                      I request your valuable help.
                      • Hishamawada
                        • 174
                        Did u try what i have suggested?
                        You can also try swapping the patch sensor.
                        Best of luck
                        • burak
                          • Feb 2019
                          • 38
                          sure i tried
                          I need to replace the patch sensor like you said.
                          • fchu5959
                            Field Engineer
                            • Jun 2010
                            • 100
                            Hello there,
                            Maybe this info below could be of some help;check it out.
                            [Symptom]
                            Unit displayed a E020-0381. Patch sensors were cleaned, the code changed to E020-0481.
                            • E020-0x81: Lower limit error in light intensity on drum base (reflecting light intensity from the drum surface). DISPLAY > DENS > P-B-P-Y/M/C/K (Measured value of drum base) < 150 (x= 1: Y, 2: M, 3: C, 4: Bk)
                            [Remedy]
                            In this case, the Cyan Developer Assembly, was replaced to resolve this issue.
                            FM4-7440 DEVELOPING ASSEMBLY
                            • burak
                              • Feb 2019
                              • 38
                              Hello there ,
                              Problem solved. ,
                              The problem went back to normal with the replacement of the black patch sensor.
                              Thanks for your help.
