IR adv C5560 E025-0450
  • copycart
    • May 2009
    • 97
    The copier started off with very faint black copies and went to no image on the copies and not trips the code E025-450. I looked at the black hopper and can turn it manually but it doesn't seem as free as the others. There is no extra noise of binding, thinking of just replacing the black hopper
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: IR adv C5560 E025-0450
    025-0450-05 Hopper Motor errorDetection Description The ATR Sensor (Bk) consecutively detected that the output (Vsig_ind) was 40 or less.
    Remedy [Related parts] R1.00
    - Harnesses connecting the Process Unit Relay PCB (UN20/J609), the Relay Connector (J5096/5P) and the ATR Sensor (Bk) (TS8/J6120)
    - Set-on Hopper Assembly
    - Developing Assembly (Bk)
    - Process Unit Relay PCB (UN20)
    [Remedy] Check/replace the related harness/cable, connector and
    What's the dev unit like check drive coupling on dev assy if the hopper assy is harder to turn than the others that's probably the problem
    Regards Mark
