Change machine model or running speed?
+ More Options
Posts
  • haydar64
    Hi all.
    Can i change machine model or running speed with firmware or other software?
    i have ir 5055,5065,5075 and very more machines.
    can i change my ir5055 to 75 copy machine (ir5075 or 5065)???
    is ir5055 or ir5065 machine runs like ir5075?
    thanks for interests.
    HAYDAR64
  • Van Steal
    • 177
    No
    • Luther
      • May 2006
      • 682
      Ok I'll bite.................why would you want to do this?
      • Eric1968
        • 2458
        Don't mess with firmware!!!!
        • CanonHPTech
          • Apr 2007
          • 235
          A little coffee in the toner hopper goes a long way. I would say no.
          The glass maybe half full, but less is more...
          Printer + Fax + Copier = Jack Of Many Trades,
          but Master Of None
          Color Copier = Not A Color Printer
          InkJet MFP = Not A Fax Machine
          B/W Copier = Not A Press
          Finisher = Deal Closer (salesman, not accessory)
          Copier Tech = Admin's Stress Ball (Scapegoat)
          • Irish
            • 110
            No....... unless your feeling real lucky .. and then NO
            • haydar64
              but ir2200 can be change to ir3300 (22 copy to 33 copy)
              • mrfixit51
                Lead Service Technician
                • Oct 2008
                • 1975
                And how is that performed?? I have never heard of this.
                • SteveO
                  Not possible! Nuff said.
                  • ymmtech
                    • Jun 2009
                    • 190
                    Dear sir,
                    Never heard is not equal to not exist. This is the part where SST firmware don't get involve. We can not modify ift or prg to to patch a 22s into a 33s. Something can do beside changing circuit board.
                    Last edited by ymmtech; 06-24-2009, 11:47 AM. Reason: Some words deleted so to be fair for certain party.
                    • scully
                      • Mar 2006
                      • 46
                      NO !
                      • ymmtech
                        • Jun 2009
                        • 190
                        Haydar64 albsolutely correct.
                        • j2980kh
                          • Mar 2009
                          • 69
                          Counter-chip, and serial chips will be exchanged.copy of the counter and the serial is ir5075 chips.
                          • ymmtech
                            • Jun 2009
                            • 190
                            Don't touch the counter,serial chip!
                            • goofball
                              • Mar 2009
                              • 18
                              Easy to change, just swap the front door.
