IR1643 how set # details?
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    hello
    I have problems sending
    how do i set up on the IR1643 the system to display the problem sending codes #?
    how do i see these codes?
    thanks
    "Knowledge is a source, but unfortunately ignorance is a sea."
  • 20 year tech
    • May 2014
    • 577
    Re: IR1643 how set # details?
    Should be the same as other canon's, in service mode>fax>sssw>sw01 set bit 0 to a 1 errors should than be on the reports
    • giogi
      Engineer senior
      • Jan 2016
      • 181
      correct. I thought that too but after setting those parameters and restarting the device, the report is without those details.
      What report do you recommend?
      • 20 year tech
        • May 2014
        • 577
        They should be on the communication report. I Dont have one of these around to look at but they are like an imageclass machine correct ?
