Canon IR-Adv C356i reboot problem
  • Daniel_B81
    • Jan 2019
    • 38
    Hi, we have a customer that has a problem with this machine, the problem started with that it could spontaneously start rebooting permanently so it felt like it could be a power issue problem.
    We changed the power supply on the machine and it felt like it had solved the issue until it happened again after a few days, it also have started giving a service error code E074-0002 and we changed the ITB for that issue.
    The problem still remained and we noticed that the machine usually dropped that code when the machine was not in use (after closing hours) so it still felt like a power issue and we have tried changing the All night power supply unit as well.
    It feels like the only thing left to try is now the DC Controller and Main Controller.
  • 20 year tech
    • May 2014
    • 577
    Re: Canon IR-Adv C356i reboot problem
    Have not seen it with that model but have seen that issue caused by a bad fax board. if it has one disconnect it or swap it out and see if your problem goes away.
    • Daniel_B81
      • Jan 2019
      • 38
      It's not equipped with a FAX unit.
      I have the machine next to me and it started rebooting again, what i noticed is that when it started the reboots were frequent with about a seconds delay to get longer for each try until after about 4min it booted completely, i filmed it when it behaved that way, gonna upload it and show it when it's ready.
      • 20 year tech
        • May 2014
        • 577
        Oh well so much for my fax board idea. If you haven't already done so first check the outlet, after that re-seat all the connectors on the main controller and DCON than reload system software, for what its worth my best guess is the main controller is bad, please let us know what fixes it.Good Luck
