Canon IR ADV C5035 copy quality issue
  • pestilentpapaya
    • Oct 2021
    • 1
    Hello, I am having an issue where my company prints swimming pool blueprints on 11x17. when the plans are drawn up on a computer and printed they look fine and are legible. however if someone makes a copy using the ADF or Glass scanner the copies come out messed up. I am not sure what is causing the issue but i am attaching 2 pictures. one is a normal print and one is a copy. any help would be appreciated! Thank you!Good.jpgbad.jpg
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon IR ADV C5035 copy quality issue
    Looks like an issue with the CCD, try cleaning it before replacing.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • romario
      • Jun 2020
      • 182
      Originally posted by pestilentpapaya
      Hello, I am having an issue where my company prints swimming pool blueprints on 11x17. when the plans are drawn up on a computer and printed they look fine and are legible. however if someone makes a copy using the ADF or Glass scanner the copies come out messed up. I am not sure what is causing the issue but i am attaching 2 pictures. one is a normal print and one is a copy. any help would be appreciated! Thank you![ATTACH=CONFIG]50449[/ATTACH][ATTACH=CONFIG]50450[/ATTACH]
      ccd problem
      thanks
