IRADV8505 error code E0004-001
  • Blues977
    • Jun 2024
    • 15
    Good day to all of you,
    Having iRADV8505 with error code E0004-001.
    I swap the following parts from a working condition machine to this Error code machine problem still the same : -
    1) Main driver P.C.B
    2) IH Power supply
    3) Relay board
    Any thing else I can try out ?
  • Brian8506
    • 1664
    Did you reset in service mode?
    • Blues977
      • Jun 2024
      • 15
      Yes I did reset the error in the service mode
      • ElZero
        • Sep 2021
        • 24
        E0004 is FIxing Unit related.
        • nicknt82
          • Nov 2011
          • 155
          2) IH Power supply
          3) Relay board
          Do Reset in service mode. If problem still happend then thermistors need to be replaced
          • ernesto
            • Oct 2011
            • 430
            you are rihgt. it must be replaced 3 thermistors
