Canon C5235i Single Scan Feeder stuck after few page
  • denvertan
    • May 2019
    • 82
    We have this Canon C5235i with Single Scan feeder.
    It will not pull all paper in the feeder. (Likely to stuck after 3 to 4 pages)
    We have change ALL the roller and also the pad inside the feeder.
    But issue still persist. Any help or suggestion is welcome.
  • Brian8506
    • 1664
    Did you replace the clutches? What does the jam code tell you?
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Re: Canon C5235i Single Scan Feeder stuck after few page
      Is it detecting the originals on the tray properly? Dirty sensor?
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • zeckryyu
        • Nov 2020
        • 27
        [ATTACH=CONFIG]50664[/ATTACH]
        I once had this problem....the paper sometimes stick together,last time i ask a client to check their paper 1 by 1 to make sure they dont stick,because some doc they keep for long time,and the air room make the paper stick...just my experience
        Sent from my M2003J15SC using Tapatalk
        • wcanonw
          • Aug 2014
          • 404
          Hello, could you do some tests by putting new sheets and if the normal scan is carried out without presenting any jam, if the problem persists, clean the sensors that are in the path of the paper, after having
          clean the sensors enter the adf service mode and do the sens init
