Canon iPF6100 large format printer; hardware failure 2F26
  • jody_surfs
    • Jan 2025
    • 1
    [Error Code] Canon iPF6100 large format printer; hardware failure 2F26
    Hi!
    I recently acquired a used Canon iPF6100 large format printer for free. The previous owner said it hadn't been used in a year but that it was working before. When I first started the printer, it would basically get through its boot sequence and then immediately display "hardware failure 2F26".
    After some research, I believe the fault is due to "If the motor could not be run at all or has resulted in an error after moving by a slight distance: A. A mechanical load error may be suspected." I bought some fine mechanical lubricant and lubed the drive shaft. Now the carriage moves a small amount at start up but still gives this error.
    Does anyone have experience or ideas on what else I can do to repair?
    Thank you!
