I believe the sensor here that is causing the grief is actually the ATR Sensor, mounted to the left of the developer rotary. I have seen this one cause "morning sickness" as described here. This copier even when running correctly mists all around the rotary. That is why Canon suggests that on every service call the area should be cleaned up.
