canon ir adv 8205 black spot on page toner stick on drum
  • Omkarmore
    • 17
    hey ,
    i have canon ir adv 8205 , my problem is black spot or small black line on paper because of toner stick on drum
    i have replaced following
    1) drum unit
    2) devloping assembly
    3) toner
    4) drum cleaning blade
    5) i cleaned wast toner assembly its ok
    6) change corona wire
    but problem is not solved plz help me out
    Re: canon ir adv 8205 black spot on page toner stick on drum
    Originally posted by Omkarmore
    hey ,
    1) drum unit
    3) toner
    Really only thing left is the fuser.
    • Brian8506
      • 1665
      Have you cleaned the slit glass above the drum? What about the transfer belt assembly?
      Sent from my iPad using Tapatalk
        Good catch..
        I saw blade and thought of ITB blade.
        Now that I've had some coffee I see my mistake.
        • Brian8506
          • 1665
          I had a dirty slit glass cause a line that drove me nuts for a while. You just never know.
          • Brian8506
            • 1665
            hey ,
            1) drum unit
            3) toner
            Another question. Is it copy,print or both?
            • Omkarmore
              • 17
              iam using only print fuctionof printer and i cleaned glass plate above drum but nothing happens
              is there any current issue or potential issue of drum ?
              • TEST10
                • Jun 2010
                • 69
                could you upload a picture
                • Brian8506
                  • 1665
                  Never had a drum issue with that series except the blade.
                  • romario
                    • Jun 2020
                    • 192
                    hey ,
                    1) drum unit
                    3) toner
                    hello. if you can upload a photo to verify the failure and analyze. I suggest you make a copy and cause a paper jam before the sheet reaches the fuser so you can discard the fuser unit and focus on image formation.
                    thanks
