I'm chasing a mouse here. I've gone from error code 220 to 602 to 225 and now I have 677. I can't find 5802 in the book. Get my you know what kicked.
Thanks, Kurt
Quite a range of problems. If I were you, I would follow his suggestion and make sure you have the right boot ROM, then I would format the HD, flash the boot room, and reload system software. Make sure you are using the right system software version and boot rom software.
The last code (I think) you meant E580? if so, that is a finisher issue. 802 is a universal send error code, and 5802 ?????
