IR-3245: Need Help Resolving E0804 0000
  • InlineMuse2124
    • Mar 2025
    • 1
    Hi All,
    I am facing an issue where the machine (Canon IR-3245)is displaying E0804, intermittent between copies. I have tried replacing Power Supply board and Fans. But it didn't work. I am yet to check with the Main Control Board as it is quite expensive and risky. Is there anything else to check? Can anyone help me resolve this?
    Thanks in Advance..
  • MOLICN
    • Mar 2024
    • 26
    If you know how to repair circuits and your motherboard is broken, you can replace it. There is a resistor in the fan power supply location. The reason is that it has burned out. If not, you can only replace the motherboard with a new one.
    • techandtrader
      • Jun 2016
      • 335
      i have a main cont cage for this I can sell for a reasonable price. If you still need help I can look into that code for you
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
