Canon IR Adv C5235 PQ.
  • Service@PRT
    • Oct 2016
    • 181
    Good day!
    Im having trouble with this print quality.
    The print out from full autogradation is very good.
    The print from PS test page for RGB and CMYK is very good.
    As well as the copy quality is pretty much good.
    Even in PG test the result of print quality is good.
    But when it comes to printing coming from computer after 1 print the quality of the printing is loosing. As in the pictures..
    1 is the original color and first print out.
    The next one is loosing its colors
    Tried different driver UFRII different version, PCL as well with different version also.
    5 computers and they print different quality and colors.
    All using windows 10 64bit and drivers i tried to use.
    UFR II version is LT V4 v7.1.2 and 30.30
    PCL 6 V4 v7.1.2 and v21.85
    All same result
    Sent from my YAL-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • Service@PRT
    • Oct 2016
    • 181
    Re: Canon IR Adv C5235 PQ.
    Physical check of drums and developers are all good. Even in simulations they are all ok. A month ago we just replaced all drums. With total counter of 215k as of now.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Put the same job on usb stick and print directly from printer.This will separate the problem to the printer or driver.
      • Service@PRT
        • Oct 2016
        • 181
        Forgot to try this. [emoji29][emoji29][emoji29]
