OCE Varioprint 6320 error 2517
  • nirundorn
    • Feb 2025
    • 3
    Welcome All,
    I have encountered an error on the OCE Varioprint 6320 saying:
    Error recovery (code: 2517)
    System error at the printer module
    I would really appreciate every help on the matter what can I check in order to resolve this issue.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Suspected Parts
    Primary Pin Corona
    Check life-time.
    Check for correct installation.
    Check on short-circuit.
    Replace corona unit.​
    Charge unit is not properly set up against the OPC unit
    Instruct the KO to properly set up the charge unit (K2) using the service handle.
    Filter
    Check life-time.
    Replace filter.
    Primary charge power supply
    Check wiring 02X50 - 2210X15/X21/X29.
    • nirundorn
      • Feb 2025
      • 3
      I need a repair manual for my machine canon oce varioprint 6320 service manual
      • zoraldinho
        • Mar 2008
        • 5015
        Yes. You need it.
        Call a certified Canon service technician.
