Looking for reset hex code for Canon MC-20 Maintenance Tank (ImagePROGRAF-1000)
  • vertigosystems
    • Feb 2019
    • 28
    Title says it, this is for the MC-20 tank for a Canon pro-1000.
    All these chip reads are 2KB reads, but they're padded to the end with 00s
    I've read the used chip that was marked as "full" by the printer which contains:
    Offset: 0x02: 01
    Offset: 0x18 : 37 D5 0E 00 AD 70 45
    Offset: 0x23: 6D 5F
    So i bought a "New" chip off ebay, and read the chip contents so I might be able to reset them in the future:
    Offset: 0x02: 01
    Offset: 0x18 : FE FD 0C 00 31 32 3C
    Offset: 0x23: 2D 75
    After putting this one in, the printer said the tank was "90% used" with only 10% life remaining but unlike the first chip, it would allow me to continue printing, but probably not for long. And probably not enough to initialize any new cartridges.
    So I read the chip again after the printer "initialized" it and it has this now:
    Offset: 0x02: 01
    Offset: 0x18 : 10 CF 09 00 20 13 43
    Offset: 0x23: 28 C3
    I can't figure out any pattern or algorithm that it's using, or identify anything being written to the chip that might act as a printer ID (some epson printers write the serial # to the chip after initialization)
    Does anyone have a known blank/new chip that they might have read with an i2c reader that they could share? Or perhaps someone knows what the algorithm used in the ebay chip resetter tools?
    TIA!
  • x3256
    • Feb 2021
    • 22
    Re: Looking for reset hex code for Canon MC-20 Maintenance Tank (ImagePROGRAF-1000)
    Interesting, it looks like 0x01 is some kind of header and then we have 7bytes + 2bytes of data in fixed position also, there is in the 7byte package 4th byte is 00 and 3rd contains only 0x format.
    • Garry611
      • Mar 2022
      • 1
      The chip you purchased to decode was that on a MC20 cart or third party replacement chip?
      Any further progress or results?
      The information that I've seen elsewhere is that once the chip is marked full, it cannot be reset. So the chip may need to be
      initialized, and then checked.
      • vertigosystems
        • Feb 2019
        • 28
        The chip I got was third party, I'm going to assume, there's no way to tell for sure without unpacking a brand new MC-20 from Canon.
        At the time I bought them the chip shortage was at it's height, so a $17 part was going for $100+ just about everywhere.
        I'm going to order a new MC-20 in since it's about the time of year I need my good photo printer up and running and I'm going to port-sniff the i2c on the ink tanks as well and come up with a board solution for the whole printer.
        in my op, there is a reading of "empty" of the new chip and a reading right after initialization, the problem is I can't really discern any pattern or anything from it.
        I've since purchased an eeprom emulator device which will allow me to get a realtime log of data being sent to and from the chip including addresses, so it should be a piece of cake going forward.
        If you still need any of this info, post a reply and I'll put it up here as soon as I learn anything. Time is my rarest resource righ tnow.
        • sameh
          • Oct 2014
          • 19
          Toner Chip Resetter
          Toner Chip Resetter - 100% Toner Reset
          [COLOR=var(--primary-text)]Toshiba 385 toner & drum
          Xerox 6600 6605 6545 CMYK 40
          [/COLOR]
          [COLOR=var(--primary-text)]Lexmark[/COLOR]
          [COLOR=var(--primary-text)]CS & CX 310 , 317 ,410 , 417 ,510, 517
          2130,2132
          MS310, MS312 , MS410 , MS415 ,MS510 MS610 , MS317 ,MS417 , MS517 , MS617 MS315 , MS710 , MS711, MS810, MS811 , MS812
          MX310 ,MX410 ,MX411, MX510, MX511, MX611 , MX317 , MX417, MX517 , MX617,
          MX511de, MX511dhe , MX511dte , MS510dn , MX510de,
          MS610de, MS610dn ,MX610de , MS610dtn, MS610dte,
          MX611de MX611dhe, MX611dte , MX611dfe,
          M1145 ,XM1145 , 1140 M3150 XM3150,
          M5155 ,5163 5170 ,XM5163, 5170,
          [/COLOR]
          [COLOR=var(--primary-text)]DELL 2360, 3460, 3465, 5460 ,5465,[/COLOR]
          [COLOR=var(--primary-text)]Minolta 4700P , 4000P ,3300P , 3301, 4020P, 3320 ,4050 ,4750 ,[/COLOR]
          [COLOR=var(--primary-text)]Lenovo S3300D/DN[/COLOR]
          [COLOR=var(--primary-text)]Sindoh A603 A603 dn A608 A608dn[/COLOR]
          [COLOR=var(--primary-text)]RICOH[/COLOR]
          [COLOR=var(--primary-text)]SP C231DN SP C231SF
          SP C232DN SP C232SF
          SP C240DN SP C240SF
          SP C242DN SP C242SF
          SP C311DN SP C311SF/ SFNW
          SP C312DN SP C312DNW
          SP C320DN SP C320SF
          SP C325DN SP C325SF/W
          SP C340DN SP C340SF
          SP C220DN SP C220SF
          SP C222DN SP C222SF
          SP C221DN SP C221SF
          SP C250DN SP C250SF
          SP C260DN SP C260SF
          SP C261DN SP C261SF /W
          SP C252DN SP C252SF
          SP C262DN SP C262SF /W
          SP C360DN SP C360SF
          SP C340DN SP C340SF
          SP CL4000DN
          SP C410DN
          SP C411DN
          SG2010L SG2010N SG2100 SG2100L SG2100N
          3100SNw 3110DNw 3110DN 3110SFNw 7100DN
          3350 SG31
          SP 3400DN SP 3400SF
          SP 3410DN SP 340SF
          SP 3510DN SP 3510SF
          SP 3710DN SP 3710SF SP 3710X
          SP 4500A SP 4510DN SP 4510SF
          SP 3600DN SP 3600SF
          SP 3610DN SP 3610SF
          SP-100e SP-100SFe SP-100Sue 110 111 112 101
          SP 150su SP 150w SP 150suw
          SP 200 202 203 210 212 213 220 s/su/n/sf/sfn/nw
          SP 300DN SP 300
          SP 311 sp311DN sp311SFNw 311SFN
          sp310SFNw 312 sp312DNw 320SN 325SFNw
          SP 400DN
          SP 450DN
          SP330DN SP330SN SP330SFN SP 330
          SP 377DNwX 377SFNwX
          P 501/ 500 / IP 500SF
          SP 6440M 6430 6430M 6430DN 6420 6420M 6410 6450
          Sp 4520 401 402
          Ricoh 4310 4210 4100
          Mc 250 c301
          C352
          [/COLOR]
