Need ImagePress C1 IP address to use Remote Operation Viewer
  • victoryprinting
    • Sep 2012
    • 53
    [Misc] Need ImagePress C1 IP address to use Remote Operation Viewer
    I have an ImagePress C1 that occasionally had some touch screen issues many years back, and I used the Canon Remote Operation Viewer so I could get an image of the touch screen on my Q1 RIP screen and select it's functions with the mouse.
    I am in need of that function again, and when I start the program, it says to enter the IP address of the machine, but I can't remember the address I used. It's not the address of the Q1, I tried that.
    Do all C1's have a fixed IP address, or is there a way to find out what the IP address of my C1 is?
    It was working at one time, so I know the software was purchased and installed on that machine.
    • 22801
    Re: Need ImagePress C1 IP address to use Remote Operation Viewer
    You didn't print out the network pages?
    What about config pages?
    Step one of any tech on a service call.
      • 2621
      Connect fiery to a computer using a crossover cable install wireshark, run wireshark.
      • victoryprinting
        • Sep 2012
        • 53
        I did print out the config pages and went over every line prior to my post - it just showed the network info for the Q1. I searched a long time for the IP for the C1, but found nothing - both through the Q1 and searching on my other C1 that has the good screen.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
          If you’re referring to the connection between the RIP and the printer, it’s either 10.255.255.1 or 10.255.255.2.
          The 2 devices use those 2 addresses, I just don’t remember which one uses which address.
          But like Skynet said, Wireshark will quickly show it; just connect and boot the machine with Wireshark running.
          • victoryprinting
            • Sep 2012
            • 53
            YES YES YES! 10.255.255.2 was the answer! I knew it was something like that, but could not remember the exact address.
            I was able to log in and now I can control the screen from the RIP. So I have a little breathing room while I get a new touch panel to get the screen working again.
            THANK YOU!
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3945
              THANK YOU!
