irc3200n bad print quality
  • smiley
    • Aug 2008
    • 616
    helo guys please help me i have 3200 with n bootrom and im using pcl5c driver and the print output is very defferent from the original ducument.it prints darker and dead.when i used it as copier it has a good copy quality.please help me what i need to do.
    there is no glory without sacrifice
  • SCREWTAPE
    • May 2025
    Try using the UFR print driver, chances are the quality won't change much when you using these type of print driver. If you have a imagepass the print qaulity would be better. Post script drivers are better to use when you want to achieve better output. Do you have a image pass? We also have to keep in mind the drumlife, how are the drums are they old? Try doing a full auto gradation and see if that helps.
    • smiley
      • Aug 2008
      • 616
      hi screwtape i dont have image pass .and i will going to try ufr and ps i will post if the image changes.thanks for the reply.
      • SCREWTAPE
        • May 2025
        hi screwtape i don't have image pass .and i will going to try ufr and ps i will post if the image changes.thanks for the reply.
        You only could use the post script driver if have a imagepass! If you have a canon print controller the only option you have is pcl and UFR if I'm not mistaking. Remember these machine are business color.
        • smiley
          • Aug 2008
          • 616
          hi screwtape thanks for the replay the ps driver solves the problem.i try to use the ufr but nothing happen.thanks again.
          • SCREWTAPE
            • May 2025
            hi screwtape thanks for the replay the ps driver solves the problem.i try to use the ur but nothing happen.thanks again.
            No problem!
            As i said, "If you have a canon print controller the only option you have is pcl and UFR if I'm not mistaking. "
            I was unaware that there was a PS driver option for the canon controller. Normally, the user software that comes with the printer kits, its options are UFR2 or PCL5e,PCL5c. I usually use PS drivers when the machine comes with a EFI controller (imagePass).
            So i guess we thought each other something. Take care,
            Screwtape
            • smiley
              • Aug 2008
              • 616
              thank you so much for helping me. take care to.
              smiley
