IRADV C5051 Color Spots
  • RHodg57
    • Dec 2013
    • 191
    These spots suddenly appeared on an IRADV C5051 with over a million copies on it.
    All 3 Colors only and not black. I have been working on these machines since they were
    first out and have never seen this before. I stopped a copy job half way on an 11 x 17 page
    and the spots appear on the color drums and the IT belt. Checked the manual concerning
    image faults and nothing like this is shown.
    I have done the simple thinks like unplugging the copier and restarting.
    I am going to search through some tech pubs I still have on these old machines.
    I had went back to the machine to change the magenta drum unit due to streaks and discovered afterward that it was making the spots. Thought maybe it was something I had done but then found out it was a different issue that had occurred before I had returned.
    I realize it could possibly be developers but for all 3 to do that at the same time would be very odd.
    Any Hints besides recommending the customer upgrade?
    Re: IRADV C5051 Color Spots
    If the drum(s) aren't ' burned or etched ' more than likely there is glue on the drums and belt from running cheap labels.
    You can clean it off with a soft cloth and IPA.
    Just don't scrub hard or use a scrubby pad.
    • hidius
      • Jun 2015
      • 128
      replace the toner filter behind the machine will reduce this issue. there was a tech article about this issue.
      • RHodg57
        • Dec 2013
        • 191
        Do you have that article?
        • 40yearsplus
          • May 2020
          • 113
          Just some Ideas.
          You stated you stopped the paper and saw the spots on the drum, so im guessing this was before the cleaning of the drum. You said you swapped a Drum and it stayed the same for one color also, so you are basically saying its not the drums.
          You should pull the developer and spin it and look for spots or substitute it. This is also assuming your ITB cleans itself off properly and the internal transfer rollers are good.
          Is this something that has been down a long time or in a bad environment? Did they buy the toner fresh from you, and it was not sitting around at all a long time or in the weather.
          But for you this should end up being pretty easy due to you worked on these since they came out.
          Without the info you gave us i could have guessed bad recovery mylars in the drum, now check the developers for dropping toner.
          I don't work on this just giving you some ideas to follow. 1 Million is high for a color copier maybe you can upgrade in the near future, GL.
          • 40yearsplus
            • May 2020
            • 113
            Remember your ITB cleaning unit also make sure its not clogged or waste toner full.
            • copicatt
              • Nov 2008
              • 366
              Theres definitely a drum size pattern of dots....Took me a bit to find it haha
              • MunsterTech
                • Sep 2014
                • 381
                looking at the photo supplied of the spots, the spots are repetitive, same patten every 3-4 inches or so?
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5015
                  Primary charge roller on Cyan and magenta drum.
                  • RHodg57
                    • Dec 2013
                    • 191
                    It was easier to see when I ran a test page on 11X17
                    • RHodg57
                      • Dec 2013
                      • 191
                      I put a used ITB unit, developer and drum in the machine (all for the cyan) and that got rid of cyan spots.
                      I tried cleaning the belt and the drum that I had removed as you suggested and made sure there wasn't anything going on
                      with the developer but the spots did not go away with those parts reinstalled. The belt and the developers were long past due for being changed. Gave an estimate and the customer is going to upgrade.
                      I have had a couple machines where labels got stuck to the itb and I was able to remove them and clean off the adhesive.
                      The drums we get for those machines are not the genuine drums but I have never had that kind of problem occur.
                      Still not sure why the black wasn't effected. Thanks for you suggestions!!
                        Sounds like the development unit ( being out of life ) could be the issue.
                        But I am leaning more towards the non oem drums.
                        Do the have coronas or pcr?
                        If pcr clean it with NuFinish.
