Canon iPR C650 stationary jam 020B
  • krolinho
    • Apr 2025
    • 3
    [Jamming] Canon iPR C650 stationary jam 020B
    Hello,
    for several months I have been struggling with the problem of jams in the imagePRESS C650 machine. When printing from the C1 lite deck, the sheet stops during fusing (I have attached a photo). The machine works without a jam from the other drawers and feeders. When the machine is "rested", it makes the first 20-25 sheets without a problem even from the C1 lite deck, but during longer work it jams every few or every one sheet. It looks like the rollers pick up the paper, but do not start at the moment when they should feed it into the printer.
    In the main machine I replaced both fusing belts and thermistors, the registration unit was recently replaced. In the POD Deck Lite C1: rollers, clutches, pick-up motor, and also the main board.
    I have no more ideas and I feel completely helpless, please help me solve the problem.
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    00020B: Jam Code (Registration Unit) 020B
    [Symptom]
    00020B: Jam Code (Registration Unit) [Remedy]
    Type: STNRY
    Sensor Name/Description: Registration Sensor
    Sensor ID: PS28
    Note: -
    I/O mode: Service Mode > COPIER > I/O > DC-CON > P021 > bit2
    • krolinho
      • Apr 2025
      • 3
      PS28 sensor is functional because the machine works fine with other feeders.
      • Lefthandedscrews
        • Dec 2022
        • 4
        If all trays are working it seems like you have issue with the deck C1. Check properly the pick up assembly section there might be deform plate or not level. Check also the jam history if it register more on delay jam than stationary jam.
