Canon iR-ADV C7565 III Cyan fading streaks
  • John Doe
    • Apr 2025
    • 5
    This is a lightly used machine. Toner, etc. all OEM. All parts OEM.
    There are diagonal faded streaks across the cyan image beginning at the leading edge of the page. I have replaced the cyan image drum, but the problem is now slightly worse. The image here is from a test print after the drum change.
    Any suggestions on where to go from here?
    Chris
  • tinnyjay
    • Oct 2009
    • 654
    Change cyan developer.
    "Who loves the roses,must also bear thumbs"
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4999
      I agree. It seems like a lack of starter in the cyan developer.
      • John Doe
        • Apr 2025
        • 5
        I have a second c7565 in storage. Is there any reason not to swap the entire cyan processing unit to see if that corrects the issue prior to replacing the developer?
        • tinnyjay
          • Oct 2009
          • 654
          When we say to change the developer, we mean change the developer unit. Swap only C developer unit.
          It's not a big deal, believe me.
          • John Doe
            • Apr 2025
            • 5
            Many thanks to tinnyjay and zoraldinho for their kind assistance.
            It was, indeed, the cyan developer. Swapping it corrected the issue. The replacement developer has about a 100k impression count, so hopefully it will serve for some time before having to be replaced with a new one.
            Here is a pic of the bad developer in which the streaks are visible on the roller. After that is a pic of the test page after replacement.
            Chris
            • zoraldinho
              • Mar 2008
              • 4999
              Good job! 😀
