Canon ir3225 not warming up only green light
  • universaltvm
    • May 2010
    • 52
    Ir3225 not warming up only green light glows. I reseated memory. Same issue. I have noticed a red led blinks in main control pcb. Plz help....
    Sent from my POCO M2 Pro using Tapatalk
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon ir3225 not warming up only green light
    Symptom of dead main controller.
    • Brian8506
      • 1664
      Ditto. Just had the same problem a month ago
      Sent from my iPad using Tapatalk
      • kstan268
        • Apr 2012
        • 85
        You can try short circuit the two point at beside the back up battery in main com
        • universaltvm
          • May 2010
          • 52
          I had done
          • kstan268
            • Apr 2012
            • 85
            Originally posted by universaltvm
            I had done
            Then it most chance is main con problem..but before you replace main con try replace control panel sometime it also couse by control panel also
            • universaltvm
              • May 2010
              • 52
              Ok. In Main controller a red light is flickering. No other lights like power gud is not glowing
              • kstan268
                • Apr 2012
                • 85
                Then confirm is main con faulty
                • universaltvm
                  • May 2010
                  • 52
                  Ok
                  • universaltvm
                    • May 2010
                    • 52
                    Ok
                    Replaced the power supply working fine nw
