Ir adv 4235
  • kstan268
    • Apr 2012
    • 85
    Ir adv 4235
    Is any big bro having double side jam in this model???Last model is ir3235 also having this kind of problem but after using drum claw it beome less.Is there a drum claw for ir adv 4235..?
  • Brian8506
    • 1664
    • kstan268
      • Apr 2012
      • 85
      Re: Ir adv 4235
      can tell me more detail how you solve this problem?which sensor spring??
        Re: Ir adv 4235
        A tech since 1996 and you can't figure out which sensor to put the extra wrap on?
        • kstan268
          • Apr 2012
          • 85
          Re: Ir adv 4235
          Yes pls tell me which sensor need to put extra wrap to solve the double side jam problem
          • Brian8506
            • 1664
            Re: Ir adv 4235
            Usually its the one in the housing that holds the transfer roller but there's a second one on the door. What's the jam code?
            • kstan268
              • Apr 2012
              • 85
              Re: Ir adv 4235
              jam code 107 delay jam
              • Brian8506
                • 1664
                • Brian8506
                  • 1664
                  Re: Ir adv 4235
                  When it does work does the lead edge vary? You could have a registration clutch problem also.
                  • kstan268
                    • Apr 2012
                    • 85
                    Re: Ir adv 4235
                    change the clutch .problem still occur
                    • Brian8506
                      • 1664
