canon ir6000
  • tekhock
    • 16
    canon ir6000
    my machine is ir6000,and print out with background. after i turn off potential control the print is ok and no more bacground. how to adjust the potential setting?
  • 20YRSEXP
    • Oct 2008
    • 281
    You don't give us much information here, copy count would help. But I would say start with a good PM. When you say print is it doing it in copy mode too?
    Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
    • smiley
      • Aug 2008
      • 615
      hi this machine need to change corona wires frequently. in order to maintain a good copy quality.
      there is no glory without sacrifice
      • jtecks
        • Dec 2008
        • 13
        Either replace potential unit or if you use gold wire instead of slightly oxidized tungsten you will get background.
        • ReproKev
          • 273
          Ditto on restringing the wires (with the correct type of wire). They only seem to go about 50k before having quality issues. I usually replace the whole corona assm's somewhere between 500k and 1 mil.
