IR 7095
  • Chaw
    • Mar 2009
    • 48
    IR 7095
    Hello Forum just wanted to know if someone could help me with an Error Code E202 for the ADF of a 7095 I changed out the Motor and the HP Sensor but still having the same issue.when the machine is first turned the scanning lamp tries to move forward to make the necessary adjustments and locate the home position. The assembly never goes forward it just makes a real loud banging noise, but if I advance the scanning lamp all the way to the right it returns back to the left side, but when it tries to make that last adjustment for the home position it makes that banging noise and pops the error code. I advanced the assembly and it moved back and forth with ease.
    Thank you guys for all your help
  • 20YRSEXP
    • Oct 2008
    • 281
    I would try the interface PCB #FM2-4820-000, I would suggest a new motor at the same time. It would not be the first time they've had to be done together.
    Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
    • Chaw
      • Mar 2009
      • 48
      Thank you that was the next thing that I was going to change out I hope that works, thank you for you help have a great day.
