Canon ImagePress C8000VP Error Code E000260-0026-05
  • TMP
    • Feb 2022
    • 1
    [Error Code] Canon ImagePress C8000VP Error Code E000260-0026-05
    Can anyone please tell me what Error Code E000260-0026-05 means and what we need to do? Thank you.
    Re: Canon ImagePress C8000VP Error Code E000260-0026-05
    You might also want to put in a request in Manual Request forum.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 4999
      Process Unit Cover ReleaseLever 2 may not be properly set.
      • Hishamawada
        • 174
        There is a circuit breaker at the rear , check it.
        also check the power to the printer if all Phases are OK.
        • khattab.al.masry
          • 212
          [Symptom]
          Power supply error
          [Cause]
          The Environment Heater Driver PCB did not detect 5 V.
          Or overcurrent was detected.
          [Remedy]
          [Related parts] R1.00
          Possible causes of the error are as follow: caught harness or open circuit of the harness/poor connection of the connector or poor conduction.
          - Harness between the Environment Heater Driver PCB (UN101/J4403) and the Main Station Power Supply Relay PCB (UN102/J1826) (Unit of replacement: CABLE, REAR, LEFT UPPER)
          - Harness between the Environment Heater Driver PCB (UN101/J4404) and the DC Controller PCB 1-1 (UN198/J1054) (Unit of replacement: CABLE, REAR, LEFT UPPER)
          - 5V line and parts to which power is supplied from the Environment Heater Driver PCB
          - Environment Heater Driver PCB (UN101) (Unit of replacement: ENV. HEATER DRIVER PCB ASS'Y)
          - Main Station Power Supply Relay PCB (UN102) (Unit of replacement: POWER SUPPLY CONNECT PCB ASS'Y)
          - DC Controller PCB 1-1 (UN198) (Unit of replacement: DC CONTROLLER PCB ASS'Y, 1)
          [Remedy] Perform the following in the order while checking whether the error is cleared.
          1. Check the installation of the Process Unit Cover.
          2. Check/replace the related harness/cable, connector and parts.
          [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2 min) and restore the backup data after the replacement so the data may be able to be protected.
          - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
          - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES
