C5860 service mode?
  • Joe Foe from Buffalo
    • 399
    C5860 service mode?
    Had a c5860 with a bad operation panel can not get in via operation panel display via old display. a new panel needs to be adjusted, aligned in service mode when I do get in service via hiden buttons on back of display I can not navigate threw service to get to the aliment of panel. What can I do?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    When you get to service mode, press number 5 until the white calibration screen appears.
    • hutmah
      • Sep 2017
      • 19
      On the DX that does not have a keypad you follow the same procedure but you hit hard key 1 or 2, I don't remember which one, a few times to jump directly to the calibration screen.
        • 399
        If you don't remember this machine does not have a keypad it's all part of the display. I won't be able to press number 5 or...1 ...or 2
        • zoraldinho
          • Mar 2008
          • 5018
          When you are in service mode, a keypad appears on the right side.
            • 399
            The calibration is so far off I can't press anything on the display... Before the operation panel was replaced calibration was attempted throwing everything off even more
            • RogueElement
              • Nov 2024
              • 8
              Knowledge Base Article KB0354996 might be able to help you.
                • 399
                Apparently I don't remember where I met my ex-wife. Please consider posting details I'd like to get to this call sooner than later Mary Kay didn't call me back to try get in sooner then later. It's been a good 8-10 months since I logged in that might be an issue
                • RogueElement
                  • Nov 2024
                  • 8
                  Fingers crossed
                    • 399
                    Wow you're awesome This should work! Thank you πŸ‘πŸΌπŸ‘πŸΌ
