I have three Damper Pad Problems I need to solve.
  • techandtrader
    • Jun 2016
    • 330
    One is the C5000 Series Inner Finisher delivery tray damper strip. I am curious if anyone has found a solution for that other than ordering a new tray.
    Second
    I used to use a FG6-9432 ???? Damper that was at least 1/8 inch thick. No longer can buy. I used these to quite down the 4570 C3480 ADF lifter/ Feed Roller. There was another updated one to replace the ones in the door duplex flapper paper path that had a plastic cap on the foam. Also no longer available. I will look for some 1/8 inch foam strip for those.
    Third
    2 sided Solenoid on C3480 3030 ADF. There is a round damper on the plunger that falls apart. I am going to try to fit a rubber O ring in there. I do not know of any round foam dampers to use for this.
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
